Free Shipping:Slate 7 Pro (GL-BE10000) | Tri-band Wi-Fi 7 Travel Router
Original price €245,98 - Original price €245,98
€245,98
€245,98 - €245,98
Current price €245,98
⚠️Before You Buy
  • EU Local shipments
  • Products with "Ship From China" tag are shipped from outside the EU and are subject to TAX & VAT & longer delivery time.
World's First True Tri-band Travel Router
Slate 7 Pro (GL-BE10000) is the world’s first travel router to redefine the limits of networking by unleashing the full power of tri-band Wi-Fi 7 aggregation. Equipped with an intuitive 2.8" touchscreen, it allows you to manage key network functions with a single tap. Beyond speed, it provides pro-grade security through integrated DPI and high-speed VPN to safeguard your privacy in any environment. With Slate 7 Pro, you don’t just connect to the world—you challenge its boundaries. Choose your office, secure your data, and embrace the freedom to work from anywhere without compromise.
Tri-band Wi-Fi 7 with MLO: Faster and more stable connections using tri-band aggregation and Multi-Link Operation.
Intuitive 2.8" Touchscreen: Real-time monitoring and one-tap basic network management.
High-Speed VPN with Obfuscation: Up to 1100 Mbps (WireGuard®) with obfuscation to bypass restrictions.
Advanced Network Security: Integrated DPI to easily identify and block malicious traffic.
OpenWrt Customization: OpenWrt support for professional-grade flexibility and plugin support.
Seamless Wired Connectivity: Dual 2.5G ports and a versatile Type-C 3.0 data port.
Wi-Fi 7
Advanced Tri-Band Connectivity
Blazing-Fast VPN
Max. 1100 Mbps
Smart Touch Interface
VPN Obfuscation
Bypass Traffic Inspection
OpenWrt-based SDK
Flexible
Customization
Advanced
DPI Shield
Tri-band Aggregation
Dual 2.5G Ports
Boosted Wired Connections
Multi-WAN
Failover
One-Tap Network Control
Slate 7 Pro makes networking effortless with its responsive 2.8" touchscreen. Manage essential features directly on-device to save time and effort. Instantly toggle VPNs, share Wi-Fi, and monitor status with a single touch, giving you immediate control the moment you power on.
Get Started Instantly, No App Required
From Power-On to Connection—No App Required
Toggle VPNs and Switch Providers in Seconds
Pro DPI Security, Compactly Delivered
Slate 7 Pro delivers professional-level precision in a sleek, compact design. By integrating Deep Packet Inspection (DPI), it moves beyond basic tracking to analyze data in real-time—giving you the power to monitor and protect your network, anywhere.
Intuitive Traffic Insights with Visual Precision
Smart Web & Content Filtering
Optimized Bandwidth Management
Stable Connections for Critical Tasks
Professional Network Sovereignty for Remote Teams
Enterprise-Grade Security for Family & Small Business
Seamless Connectivity for Virtual Collaboration
Stable Performance for Critical High-Load Tasks
Always-On, High-Speed Networking
Slate 7 Pro features dual 2.5G ports—including one configurable WAN/LAN—and a USB-C port for tethering, enabling fast, flexible connectivity with seamless Multi-WAN failover.
Mission-Critical Reliability for Business Travel
High-Bandwidth Production in the Field
Professional-Grade Home Lab & Remote Work
Unlock Flexible, Customizable Networking
Built on OpenWrt 21.02 (Kernel Version 5.4.281) with 1GB DDR4 RAM and 512MB NAND Flash, Slate 7 Pro provides the freedom to evolve the router’s capabilities through extensive plugin support and deep customization.
Tri-band Wi-Fi 7
Tri-band Wi-Fi 7
Touchscreen
Touchscreen
DPI
DPI
Multi-Link
Operation
VPN Client Server
VPN Client /
Server
OpenWrt Support
OpenWrt
Support
Dual 2.5G Ethernet Ports
Dual 2.5G
Ethernet Ports
PD Power Supply
PD Power Supply
Specifications
Interface 1 x 2.5G WAN Ethernet port
1 x 2.5G LAN Ethernet port
1 x USB 3.0 Type-C port
1 x Type-C Power port
1 x Reset button
1 x Toggle button
Memory / Storage DDR4 1GB / NAND Flash 512MB
Antennas 2 x foldable external Wi-Fi antennas
Power Input USB PD 5V/3A, 9V/3A, 12V/2.5A
Power Consumption <20W (without USB)
Dimension / Weight 130 x 91 x 36mm / 328g
  • CPU: MediaTek, Quad-core @2.0GHz
  • Memory / Storage: DDR4 1GB / NAND Flash 512MB
  • Wi-Fi Speed: 688Mbps (2.4GHz), 2882Mbps (5GHz), 5764Mbps (6GHz)
  • Antennas: 2 x foldable external Wi-Fi antennas
  • Cellular: /
  • Battery: /
  • TF Card Slot: /
  • USB Port: USB 3.0 Type-C port
  • Ethernet Port: 1 x 2.5G WAN Ethernet port; 1 x 2.5G LAN Ethernet port
  • Power Input: USB PD 5V/3A, 9V/3A, 12V/2.5A
  • Power Consumption: <20W (without USB)
  • Dimension / Weight: 130 x 91 x 36mm / 328 g
  • 1 x Slate 7 Pro (GL-BE10000) Router
  • 1 x User Manual
  • 1 x Thank You Card
  • 1 x Power Cable
  • 1 x Ethernet Cable
  • 1 x Power Adapter with Converters (US,EU,UK and AU Plugs)
New Arrival Recommendation 🚀
Category
Product Initial Setup Guide
Overall rating: 5.0 / 5 from 15 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["support","display","router"].
Review highlights
Reviews
Slate 7 pro finally arrived!
"Finally, Slate 7 pro has arrived and working like a charm! the reasonable touch screen help a lot for first time setup and settings during operation. recommended for (not only) travelers!"
GLiNeter (5/5)
"Der Slate 7 Pro (GL-BE10000) ist ein leistungsstarker Wi-Fi-7-Reiserouter mit umfangreicher Ausstattung, schnellen VPN-Verbindungen und vielen Konfigurationsmöglichkeiten. Kritikpunkt ist die starke Wärmeentwicklung: Selbst im Leerlauf wird das Gerät ungewöhnlich heiß und wirkt stellenweise eher wie eine kleine Taschenheizung als ein Reiserouter. Wer die hohe Temperatur akzeptiert, erhält dennoch ein sehr leistungsfähiges und flexibles Gerät."
Christoph G. (5/5)
Really good router and awesome customer support!
"The router is really good! The build quality and the things which you can do with it is really a lot! I recommend it a lot! I needed also help with some settings and I received so far the best customer support! Great job GL. iNet!"
Valentin N. (5/5)
Great compact router!
"It does its job as expected, the screen helps too. I really enjoy the device"
Oleksii U. (5/5)
Fantastic
"I also used outdors in stadium and it covers it all"
IVAN C. (5/5)
Very good
"Very good product. First tests seems very satisfying"
Fabien E. (5/5)
Great!
"Great router with good display!"
Marc G. (5/5)
Excellent and mature product
"This new router combines the advantages of its predecessors with the addition of a touchscreen, which is very useful for checking the status and adjusting settings. I find this router perfect for my travels, as it allows me to connect all my devices securely and with a pre-configured VPN. A great device that I highly recommend."
Jean-Philippe (5/5)
"Really good build quality and excellent performance. The customer support is outstanding. I can definitely recommend GL. iNet!"
Chris N. (5/5)
Der Beste Router:hands_heart:
"Ich mag das neue Display sehr und die große Summe der Verbesserungen"
HPY (5/5)
Q&A
