New Mint Green Color
Why should tech stay boring? The new Beryl 7 brings a refreshing Mint Green finish—soft, modern, and designed to stand out beautifully wherever you go. It’s not just a router; it’s a style statement.
As a fully upgraded version of our Beryl AX, Beryl 7 is a compact dual-band Wi-Fi 7 travel router that delivers the fastest VPN speeds (up to 1,100 Mbps via WireGuard®) in GL.iNet's travel router lineup. With PD compatibility, it can be powered using a standard phone charger cable, which not only reduces the weight and clutter in your luggage, but also makes it much easier to keep your travel router powered up. Capable of supporting 120+ devices concurrently-all in a sleek, portable design built for life on the go.
Fast Wi-Fi speeds: Max. 688 Mbps (2.4 GHz) + 2,882 Mbps (5 GHz)
Robust VPN performance: Max. 1,100 Mbps on WireGuard® and Max. 1,000 Mbps on OpenVPN-DCO
Streamlined travel convenience: Universal USB-C charging compatibility
Versatile high-speed connectivity: Dual 2.5GbE ports and support for 120+ client devices
Boosted Wired Connections
Max. 1100 Mbps
for True Mobility
AdGuard Home
Multi-WAN Failover
OpenWrt-based SDK
Flexible CustomizationBuilding on the success of the Beryl AX, the new Beryl 7 represents a major leap forward, engineered with key upgrades and differences for a more connected world.
Why pay a separate internet fee for every device? The Beryl 7 is your key to significant savings on the go. Simply connect it to the paid network once, and then share secure Wi-Fi with your phone, laptop, tablet, and more-all under a single access cost. Maximize your connectivity while you minimize your expenses and effortlessly bypass the captive portals with a one-time setup-no repeated logins required.
*Note: Travel routers may be prohibited by some cruise lines. Please check the specific regulations of your cruise line before use.With Beryl 7, any hotel room can become your private theater. Connect to the hotel Wi-Fi, activate the built-in ultra-fast VPN client to access your home server, and plug in your streaming device or smart TV. Instantly, enjoy your personal media library and stream 8K content at high speed with complete privacy—as if you never left home.
Beryl 7 makes media and document sharing effortless during group travel. Connect an external USB drive to instantly create a private network storage space, supporting 120+ connected devices simultaneously. Family members or team members can securely access and share photos, videos, and work files—without relying on unstable public networks or limited cloud services. Everyone stays connected through a centralized, secure hub, making collaboration and memory-sharing seamless wherever you go.
With Beryl 7 acting as a VPN client, you can securely connect back to your home network anytime, anywhere. Paired with the Brume 3 (GL-MT5000) at home, it enables seamless remote access to your NAS devices, letting you manage files, stream media, or even perform real-time photo backups directly to your home storage. This setup ensures your personal data remains private and protected over encrypted connections, while giving you LAN-like access as if you were physically at home.
For digital nomads, a reliable internet connection is essential. Beryl 7 can turn any location—a café, co-working space, or beachside apartment—into a secure, productive remote office. It ensures crystal-clear VoIP calls and stable video conferences, while a dedicated guest network keeps your main connection secure for client collaborations.
For business travelers, accessing company resources restricted to specific office IP addresses can be challenging. Beryl 7 solves this seamlessly. Pre-configured with OpenVPN and WireGuard, it can act as a VPN client to securely connect back to your office network, giving you access to internal systems, file servers, or managed printers—as if you were physically in the office—all over a fully encrypted connection.
Never settle for weak signals. Beyond multiple connection methods—including Ethernet, Wi-Fi repeating, and cellular tethering—Beryl 7 is truly smart. Its advanced Multi-WAN feature provides automatic failover, constantly monitoring networks and switching to the best available connection to prevent drops. This ensures a robust, private network with the consistent high performance needed for gaming, 8K streaming and other data-intensive tasks.
Beryl 7 can turn your MiFi or smartphone data plan into a high-performance Wi-Fi 7 network. Simply connect via USB and activate tethering mode, and it will receive the cellular signal and rebroadcast it as a superior Wi-Fi network throughout your space. With support for over 120 simultaneous connections, every device enjoys stable, high-speed internet—eliminating weak signals and connectivity limitations once and for all.
Beryl 7 lets you and your roommates bypass geographical restrictions simultaneously using a single VPN account. Supporting 30+ VPN service providers, this compact router provides seamless access to region-locked streaming services and video game platforms across all your devices. It also lets you apply VPN protection to the entire network or select specific devices, eliminating the need for individual per-device VPN subscriptions while ensuring everyone can enjoy their preferred content without compromise.
For homelab enthusiasts and media collectors who travel, the Beryl 7 ensures your entire home network is always within reach. By establishing high-speed encrypted tunnels via WireGuard or OpenVPN, it provides seamless, secure access to your home servers, development environments, and personal media libraries from anywhere. This eliminates the risks of public internet exposure while delivering LAN-like responsiveness, letting you manage critical services or stream your movie collection as if you were locally connected.
Beryl 7 enables seamless wireless control for Ethernet-only devices through a simple setup: connect the device to the router's LAN port and use your smartphone or tablet for wireless management. This compact solution is ideal for digital audio systems, mini-PCs, PLCs, and other equipment lacking native wireless capability. With flexible uplink options including Wi-Fi relay, Ethernet/USB tethering, plus built-in VPN support for secure data transmission, Beryl 7 provides a complete connectivity solution in a minimal footprint.
BEST Travel Router!
Gl.iNet Slate 7 PRO Travel Router Revealed
The Newest Travel Routers...
Gl.iNet Beryl 7, Comet 5G and Flint 3e Revealed
Beryl AX (GL-MT3000)
Beryl 7 (GL-MT3600BE)
Reliable Wi-Fi 6 for Basic Travel Needs
High-value Wi-Fi 7 for Speed and Affordability
MediaTek, Dual-core @1.3GHz
MediaTek, Quad-core @2.0GHz
DDR4 512 MB / NAND Flash 256 MB
DDR4 512 MB / NAND Flash 512 MB
10/100/1000 Mbps
100/1000/2500 Mbps
574 Mbps (2.4GHz), 2402 Mbps (5GHz)
688 Mbps (2.4GHz), 2882 Mbps (5GHz)
Max. 300 Mbps
Max.1000 Mbps
Max. 300 Mbps
Max.1100 Mbps
Type-C, 5V/3A
Type-C, 5V/3A, 9V/3A, 12V/2.5A
120 x 83 x 34mm / 196g
120 x 83 x 34mm / 205g
| Interface | 1 x WAN Ethernet port 1 x LAN Ethernet port 1 x USB 3.0 port 1 x Type-C Power port 1 x Reset button 1 x Toggle button |
| CPU | MediaTek, Quad-core @2.0GHz |
| Memory / Storage | DDR4 512MB / NAND Flash 512MB |
| Protocol | IEEE 802.11a/b/g/n/ac/ax/be |
| Wi-Fi Speed | 688Mbps (2.4GHz), 2882Mbps (5GHz) |
| Antennas | 2 x foldable external Wi-Fi antennas |
| Ethernet Speed | 10/100/1000/2500Mbps |
| Power Input | Type-C, 5V/3A, 9V/3A, 12V/2.5A |
| Power Consumption | <12W (without USB) |
| Operating Temperature | 0 ~ 40°C (32 ~ 104°F) |
| Storage Temperature | -20 ~ 70°C (-4 ~ 158°F) |
| Dimension / Weight | 120 x 83 x 34mm / 205g |
| Tools & Downloadables | Firmware | App | Unboxing | Tutorials | Media Kit |
