Flint (GL-AX1800) Wi-Fi 6 Home Secure Router with EU plug
Original price €102,99 - Original price €102,99
€102,99
€102,99 - €102,99
Current price €102,99
⚠️Before You Buy
  • EU Local shipments
MEET FLINT
Secure and Ultra Fast Wi-Fi 6 Wireless Router for Home or Office
Secure & Powerful Wi-Fi 6 Router
Flint (GL-AX1800) is a dual-band Wi-Fi 6 router with connection speed of up to 600Mbps (2.4GHz) + 1200Mbps (5GHz). It can run VPN encryption speed of up to 667Mbps and host VPN servers. Flint is perfect for heavy-duty data transmission, mass device connectivity or ultra-low latency gaming.
Max. 600Mbps (2.4GHz) + 1200Mbps(5GHz) Fast Wi-Fi Speeds
Excellent Security with VPN, IPv6 & WPA3
AdGuard Home Supported
Supports MU-MIMO
Learn More
Support Max. 120 Connected
Wireless Devices Simultaneously
Tip the Scales of Victory
Flint (GL-AX1800) Wi-Fi 6 router uses OFDMA (Orthogonal frequency-division multiple access) data transmission technology, significantly reducing latency by increasing bandwidth and network efficiency. This resolves the major pain points that gamers experience and provides ultra-low latency gaming enhancements.
Access Business Network Securely
100+ devices connection for multiple office collaboration
Flint (GL-AX1800) comes with Multi-User MIMO Technology, it provides a high-performance network with mass connection up to 120 devices. It ensures smooth video meetings, perfect for office environments connecting to a large number of smartphones, tablets, and computers. With IPv6 and WPA3, the next generation of Wi-Fi security, Flint can ensure all your company's sensitive data is encrypted and safely transmitted.
Upgrade Your Home Network
Faster, smoother networking experience
Flint is designed to be the safest Wi-Fi solution for your home. With its pre-installed AdGuard Home, it provides users with a smooth networking experience without being interrupted by repetitive ads and online trackers. Comes with 5 gigabit ports, you can enjoy better 4K video streaming, gaming, and video chatting with your friends and families.
No More Hackers, Access Home Network Securely
Flint (GL-AX1800) supports 30+ VPN services on OpenVPN & WireGuard®. Enabling VPN encryption on Flint automatically encrypts all network traffic within the network. With our Web UI 3.0, you can set up a VPN server easily and access your files securely in a remote site as if you are at home.
WireGuard
Max. 500Mbps
OpenVPN-DOC
Max. 500Mbps
30+ Commercial VPN services provider
Block Ads & Tracking for Free
AdGuard Home Ready on Router
AdGuard on admin panel
Block ads for all client devices
Block online trackers and analytics by default
Block age-restricted content and services as needed
Customizable DNS filters
Keep sensitive online data safe
Enforce family browsing security
Cloudflare
PREVENT MAN-IN-THE-MIDDLE ATTACKS
DNS Encryption with Cloudflare
Flint supports Cloudflare DNS over TLS, it keeps users' online actions secure and private. DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS). The goal is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Cloudflare X GL.iNet
Customize Your Own Wi-Fi 6 Router
Using Open Technologies
Flint (GL-AX1800) comes with OpenWrt operating system. The root access is granted for users to fully customize and optimize your devices. The extra storage also brings you a local drive to install different applications.
Use Flint together with the GL-M2 Development Board which is designed to connect you to a 5G network and give you the internet you deserve. With a built-in SIM card slot, the GL-M2 Development Board serves as a 5G modem for your router to get your internet up and running, whether you are residing in a remote area with no internet access or traveling on the road. Even better, the GL-M2 Development Board features multi-WAN, supporting failover and load balancing to keep you connected at all times.
KOLs Reviewing Flint
Wi-Fi 6
Wi-Fi 6
Gigabit Ethernet
Gigabit
Ethernet
VPN Client/Server
VPN Client /
Server
OpenWrt Pre-installed
OpenWrt
Pre-installed
AdGuard
Home
IPv6
IPv6
WPA3
WPA3
WPA3
Multi-User
MIMO
  • CPU: IPQ6000 Quad-core, @1.2GHz
  • Memory / Storage: DDR3L 512MB / NAND Flash 128MB
  • Wi-Fi Speed: 600Mbps (2.4GHz), 1200Mbps (5GHz)
  • Antennas: 4 x External Antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0
  • Ethernet Port: 1 x WAN port, 4 x LAN ports
  • Power Input: DC5521, 12V/1.5A (5.5*2.1mm)
  • Power Consumption: <18W
  • Dimension / Weight: 210 x 120 x 36.8mm / 445.2 g
  • GL-AX1800 Dual-band Wireless Gigabit Router (2-year Warranty)
  • Ethernet cable
  • User Manual
  • Power adapter with EU plug
Recommended Bundle Purchase
Category
Product Initial Setup Guide
