ATX Board
Original price €16,99 - Original price €16,99
€16,99
€16,99 - €16,99
Current price €16,99
⚠️About ATX Board
⚠️Before You Buy
  • EU Local shipments
Refined Product Selling Points:
Revolutionize Remote PC Management with ATX Boards
Empower your remote operations with the ability to boot and manage PCs even from a complete shutdown state, ensuring uninterrupted access and control.
Key Features:
Remote Power Control
Boot from Shutdown: Remotely power on PCs that are completely turned off, eliminating the need for physical access.
Crash Recovery: Manually restart your computer in the event of a system crash or freeze to ensure continued operation.
Seamless Integration
Comet Compatibility: Seamlessly integrates with Comet (GL-RM1) to remotely control startup and reboot, as well as perform a forced reboot in the event of a computer failure.
Enhanced Reliability
Hardware-Level Control: Operates independently of the operating system, providing robust control even during system failures.
24/7 Accessibility: Ensure your PCs are always accessible, reducing downtime and improving operational efficiency.
Applications:
Remote Workforces: Manage and support remote employees' PCs without physical intervention.
IT Administrators: Simplify large-scale PC management in enterprises and data centers.
Digital Signage: Maintain uptime for digital displays and kiosks.
Industrial Systems: Ensure continuous operation of critical industrial PCs.
Why Choose ATX Boards?
Unmatched Flexibility: Take full control of PC power states, regardless of their current condition.
Reliable Performance: Built for stability, ensuring your systems are always within reach.
Easy Setup: Direct connection to the motherboard and Comet ensures quick deployment and integration.
Installation:
Simply connect the ATX board to the PC motherboard and Comet (GL-RM1) to unlock advanced remote management capabilities.
Transform Your Remote Operations:
With ATX boards, experience unparalleled control over your PCs, ensuring they are always available when you need them—no matter the state. Perfect for IT professionals, remote teams, and businesses seeking reliable, hardware-level remote management solutions.
  • CPU: N/A
  • Memory / Storage: N/A / N/A
  • Ethernet Speed: N/A
  • Power Input: N/A
  • Power Consumption: N/A
  • Dimension / Weight: 75*44*24mm (L*W*H) / 150 g
  • 1*ATX main board
  • 1*USB-A to Type-C cable
  • 1*9 PIN Wire Set
  • 1*ATX Bracket Set
  • 1*Screw package
