Shadow (GL-AR300M16-Ext) Mini Smart Router with External Antennas
Original price €40,00 - Original price €40,00
€40,00
€40,00 - €40,00
Current price €40,00
⚠️Before You Buy
  • EU Local shipments
Shadow / GL-AR300M
GL-AR300M Series Mini Smart Router
MEET SHADOW
Mini Smart Router with Powerful Wireless Performance
Mini Smart Router
Shadow (GL-AR300M Series) offers a compact and portable design, making it ideal for small businesses, home use, and travel. Despite its mini size, it provides reliable wireless connectivity, ensuring seamless internet access in a variety of environments. With Shadow, you get a lightweight router that ensures you stay connected no matter where you are.
Max.300Mbps Wi-Fi Speed
OpenVPN speeds up to 15Mbps; WireGuard® speeds up to 50Mbps
Designed to be Portability and Travel Convenience
Learn More
Your Security is Our Priority
Added Security to Help You Stay Secure on Public Wi-Fi
4 Ways to Access the Internet
Shadow can be connected to the Internet through Ethernet cable or wireless repeater
Internet Connection - Ethernet
1. Ethernet
Internet Connection - Repeater
2. Repeater
Internet Connection - USB Modem
3. USB Modem
Internet Connection - Tethering
4. Tethering
Secure Your Connection with Built-In VPN Support
Shadow not only comes with a strong firewall but also supports OpenVPN, WireGuard®, and DNS server to boost your online security. With over 30 VPN service providers to choose from, Shadow allows you to configure it as a VPN server, ensuring secure and private access to your files as if you were connected from your home network.
WireGuard® is a registered trademark by Jason A.Donenfeld.
WireGuard
Max. 50Mbps
OpenVPN
Max. 15Mbps
Web UI
Cloudflare
ENCRYPTED DNS WITH CLOUDFLARE
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Cloudflare x GL.iNet
Similar Model Comparison
GL-AR300M-Lite
(Discontinued)
GL-AR300M16
GL-AR300M
GL-AR300M16-Ext
GL-AR300M-Ext
Ethernet Port 1WAN 1WAN, 1LAN 1WAN, 1LAN 1WAN, 1LAN 1WAN, 1LAN
16MB Nor Flash
128MB Nand Flash
USB GPIO Control
External Antennas
OpenWrt Ready
OpenWrt
Ready
Travel-friendly
Travel-Friendly
VPN Client/Server
VPN Client /
Server
GPIO Control
GPIO Control
External Antennas
External
Antennas
NAND Flash
NAND Flash
(GL-AR300M Only)
  • CPU: QCA9531, @650MHz SoC
  • Memory / Storage: DDR2 128MB / NOR Flash16MB
  • Protocol: IEEE 802.11a/b/g/n
  • Wi-Fi Speed: 300Mbps (2.4GHz)
  • Antennas: Enxternal antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 2.0
  • Ethernet Port: 1 x WAN port, 1 x LAN ports
  • Ethernet Speed: 10/100
  • Power Input: MicroUSB, 5V/2A
  • Power Consumption: <2W
  • Dimension / Weight: 58 x 58 x 25mm / 40 g
  • Shadow (GL-AR300M16) (2-year Warranty)
  • USB cable
  • User manual
Frequently Bought Together🎁
Category
Product Initial Setup Guide
