Original price €163,99 - Original price €163,99
€163,99
€163,99 - €163,99
Current price €163,99
15% off
Auto discount on add-to-cart
*Pack discount excluded
⚠️Before You Buy
  • EU Local shipments
GL-MT6000 Wi-Fi 6 AX6000 Home Router
MEET Flint 2
Flint 2 (GL-MT6000) is a Wi-Fi 6 home and office router ideally suited for heavy-duty data transmission, mass device connectivity or ultra-low latency gaming environments. Flint 2 offers blazing-fast WireGuard VPN speeds of up to 900Mbps. In addition, it also supports advanced network redundancies, including Multi-WAN, Failover and Load balance to ensure an uninterrupted network.
OpenVPN speed up to 880 Mbps (with DCO support); WireGuard® speed up to 900 Mbps
Supports Multi-WAN failover and load balancing capabilities
Features parental control and adGuard Home
Learn More
Fast. Secure. Reliable.
Multi-WAN VPN Router
Lightning-fast VPN connection
An upgrade from its predecessor, Flint 2’s VPN speeds are better and faster. Flint 2 delivers up to 900 Mbps with WireGuard and 880 Mbps with OpenVPN-DCO. Effortlessly configure your VPN client via the admin panel, providing instant protection for all connected devices, or establish a VPN server.
Whether you're working remotely, wrapping yourself in entertainment, or want an extra layer of privacy and security, your VPN speeds won't mean trouble for you.
WireGuard
Max. 900Mbps
OpenVPN
Max. 880Mbps
30+ Commercial VPN Provider
Elevating Your Internet Experience
A leap in Speed, Capacity, and Stability
Large Storage
Higher storage capacity satisfies stable online connections for over a hundred devices and meets the needs of DIY users for installing more plugins.
Powerful CPU
Quad-Core 2GHz Processor comes with powerful CPU processing capability that enhances overall product stability and provides even better performance.
Extended Coverage
Equipped with 8 high-power FEMs, expanding WIFI coverage range, meeting WIFI coverage requirements for medium-sized homes, ensuring strong signals throughout the house.
Elevate your network with 2.5G Ethernet ports
Enjoy lightning-fast 2.5G internal network transfer speeds for all your devices, whether it's a computer, NAS, or more. Embrace the future of connectivity with our innovative solution!
Turbocharge Your Internet with Wi-Fi 6
Up to 8 channels of WIFI spatial streams, Flint 2 is capable of supporting simultaneous transmission of high-definition and ultra-high-definition videos for multiple devices. It also maintains backward compatibility with 802.11AC and earlier WIFI standards.
Dominate with Uninterrupted Performance
Equipped with 8-Stream Wi-Fi 6 technology, the Flint 2 delivers blazing speeds, ensuring a stable and high-speed connection even during intense multiplayer battles.
Bark Parental Control
Keep the Family Protected
Are too much screen time and exposure to inappropriate content your top concerns as a parent? In collaboration with Bark (an award-winning child-monitoring tool), Flint 2 offers parental controls* built in to the router. In a few clicks, you can filter out certain websites and content categories, enable safe search on your child’s search engine, and manage their usage effortlessly.
Bark x GL.iNet
DFS Certification in US, CA, EU and UK
Flint 2 is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
WPA3 protocol
DNS over HTTPS & DNS over TLS
AdGuard Home
Model Comparison
Flint / GL-AX1800
Wi-Fi 6 Home Router
VS
Flint 2 / GL-MT6000
Qualcomm Quad-core, @1.2GHz CPU MediaTek Quad-core, @2.0GHz
DDR3L 512MB / NAND Flash 128MB Memory / Storage DDR4 1GB / eMMC 8GB
600Mbps (2.4GHz), 1200Mbps(5GHz) Wi-Fi Speed 1148Mbps (2.4GHz), 4804Mbps (5GHz)
10/100/1000Mbps Ethernet Speed 2 x 2.5G Ports; 4 x 1G Ports
1 x WAN, 4 x LAN Ethernet Ports 1 x WAN (2.5G), 1 x WAN/LAN (2.5G), 4 x LAN
Max.500Mbps OpenVPN (Via Ethernet) Max.880Mbps
Max. 500Mbps WireGuard® (Via Ethernet) Max. 900Mbps
210 x 120 x 36.8mm / 445g Dimension / Weight 233 x 137 x 53 mm / 761g
Flint 2 (GL-MT6000) Reviews
  • Video 0
    They cut out all the BS! - GL.iNet Flint 2
  • Video 1
    Set Up Secure VPN in Minutes with GL.iNet Routers!
  • Video 2
    The Flint 2 OpenWRT VPN Router WiFi 6 Access Point Bandwidth Tests and More
  • Video 3
    FLINT 2 GL-MT6000 ax - TUTORIAL COMPLETO
  • Video 4
    GL-iNet Flint 2 - WiFi 6 AX6000, 2.5GbE Router - Overview, Setup and Speed Test
  • Video 5
    [直播開箱]電腦討論區上面最熱門的冷門OpenWRT路由器 Flint 2 (GL-MT6000) (CC AI 字幕)
  • Video 6
    GL-iNet GL-MT6000 Flint 2 AX6000 Wireless Router Review
  • Video 7
    GL-iNet Flint 2 - Peformance Test: WAN to LAN, WiFi, VPN Throughput
  • Video 8
    GL.iNet Flint 2 Review en ESPAÑOL - El mejor Router VPN WiFi 6 que bloquea Anuncios
  • Video 9
    Proibida a Partilha de PASSWORDS em Streaming Fora e CASA? | A Solução é estar "SEMPRE" em CASA...
  • Video 10
    GL-iNet Flint 2 - USB 3.0 Network Attach Storage (NAS) Throughput Test
  • Video 11
    Discover how to quickly set up your router as a Wi-Fi Repeater for better coverage.
  • Video 12
    GL.iNet Flint 2 Multi-WAN Router Walkthrough VPN & Speed Test Review
  • Video 13
    Juega MINECRAFT sin LAG con EL MEJOR router GAMER
  • Video 14
    GL.iNet GL-MT6000(Flint 2) WiFi 6 Router6 - High Performance Home Router
  • Video 15
    ТОП РОУТЕР GL.INET FLINT 2 GL-MT6000 НА OPENWRT З НЕЙМОВІРНОЮ ПЛОЩЄЮ ПОКРИТТЯ
  • Video 16
    ТОП РОУТЕР GL.INET FLINT 2 GL-MT6000 НА OPENWRT С НЕВЕРОЯТНОЙ ПЛОЩАДЬЮ ПОКРЫТИЯ
  • Video 16
    Aumenta la VELOCIDAD DE INTERNET con ESTO! | GL.inet Flint 2
    Wi-Fi 6
    Wi-Fi 6
    AX6000
    2.5-Gigabit Multi-Gig port
    2.5G
    Multi-Gig port
    Multi-WAN
    Multi-WAN
    Dual-Ethernet WAN
    Dual-Ethernet
    WAN
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    VPN Client/Server
    VPN Client /
    Server
    AdGuard Home
    AdGuard
    Home
    DFS
    DFS
    • CPU: MediaTek Quad-core, @2.0 GHz
    • Memory / Storage: DDR4 1GB / eMMC 8GB
    • Wi-Fi Speed: 1148Mbps (2.4GHz), 4804Mbps (5GHz)
    • Antennas: 4 x 2.4GHz + 5GHz dual-frequency Wi-Fi Antennas
    • Cellular: N/A
    • Battery: N/A
    • TF Card Slot: N/A
    • USB Port: USB3.0 Type-A, Maximum 5V/2A output
    • Ethernet Port: 1 x WAN , 1 x WAN/LAN , 4 x LAN
    • Ethernet Speed: 2 x 2.5G Ports (10/100/1000/2500Mbps); 4 x 1G Ports (10/100/1000Mbps)
    • Power Input: DC5521, 12V/4A (5.5*2.1mm)
    • Power Consumption: <20W
    • Dimension / Weight: 233 x 137 x 53mm / 761 g
    • Flint 2 (GL-MT6000) Router (2-year Warranty)
    • Power Adapter, Power Plug (Base on your shipping countries)
    • Ethernet Cable
    • User Manual & Warranty Card
    Recommended Bundle Purchase
    Category
    Product Initial Setup Guide
