FREE EU regional shipping on selected hot items
Refurbished | Puli (GL-XE300) Portable Wireless Gateway with EC25-E Module
by GL.iNet
Sold out
Original price €109,00
Original price €109,00 - Original price €109,00
Current price €29,90
€29,90 - €29,90
BEFORE YOU BUY
Currently we only ship to the following countries: Austria, Belgium, Bulgaria, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Ireland, Italy, Latvia, Lithuania, Luxembourg, Malta, Netherlands, Poland, Portugal, Romania, Slovakia, Slovenia, Spain, and Sweden. If your country is not on this list, please purchase from our Global Store HERE.
- Refurbished devices are sold at low prices and do not participate in the free shipping service, additional shipping charges apply.
- Fast delivery (Products with the "EU local delivery" tag will be shipped from Germany).
- Products with "Ship From China" tag are shipped from outside the EU and are subject to shipping costs & TAX & longer delivery time.
If the shipping address you provided is not included in the above list, we will contact you to arrange a refund and cancel the order.
Bulk Order
Other Purchase Channels
N/A
Note
  • All refurbished products are officially certified and function perfectly.
Tips:
  • Refurbished Puli (GL-XE300 EC25-E).
  • One-year limited warranty.
  • Refurbished products will be shipped from EU.
  • Comes with packaging and accessories.
Puli (GL-XE300) is a portable 4G LTE Industrial IoT Gateway that is perfect for home, business, and IoT solutions. With its OpenWrt-supported feature and larger storage compatibility, it is designed for you to develop a DIY IoT project. It also comes with a 5000mAh rechargeable battery, so you can bring it anywhere with you!
Product Description:
  • Smart 4G to Wi-Fi Converter: Transfer 4G LTE signal to Wi-Fi networking. Up to 300Mbps (2.4GHz) Wi-Fi speeds.
  • Built-in 4G LTE Module: Come with a standard SIM card slot that supports the 4G LTE network. It can move into 4G LTE wireless network if the Ethernet Internet fails, in order to ensure constant data transmission. It is compatible with CAT4 and CAT6 modules from various brands.
  • Open Source & Programmable: Pre-installed OpenWrt, backed by software repository. Allows you to install different applications, perfect for DIY projects.
  • Large Storage & Extensibility: 128MB RAM, 16MB NOR Flash + 128MB NAND Flash, Max. 512GB MicroSD card support. Perfect for further extension and share files across devices.
  • Security & Privacy: OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers. With our brand-new Web UI 3.0, you can set up VPN server and clients easily. IPv6, WPA3, NextDNS, and Cloudfare supported. Level up your online security.
  • Easy Configuration with New Web UI 3.0: The built-in 4G modem supports AT command, manual/automatic dial number, SMS checking, and signal strength checking for better management and configuration.
  • GoodCloud System for Monitoring: GoodCloud makes it easy to manage and monitor our devices anytime, anywhere, and multiple GL.iNet devices at the same time. You can view the real-time statistics, set up a VPN server and client, manage the client connection list, and remote SSH to your IoT devices.
  • CPU: QCA9531, @650MHz
  • Memory / Storage: DDR2 128MB / NOR Flash 16MB + NAND Flash 128MB
  • Protocol: IEEE 802.11b/g/n
  • Wi-Fi Speed: 300Mbps (2.4GHz)
  • Antennas: Internal
  • Cellular: CAT 4
  • Battery: 5000mAh
  • TF Card Slot: 1 x microSD card slot
  • USB Port: 1 x USB 2.0
  • Ethernet Speed: 10/100Mbps
  • Power Input: Type-C, 5V/2A (with battery), Type-C, 5V/3A (without battery)
  • Power Consumption: <4.4W
  • Dimension / Weight: 120 x 74 x 28mm / 223.5 g
  • Puli (GL-XE300) Gateway
  • Power Adapter
  • Ethernet Cable
  • User Manual
