FREE EU regional shipping on selected hot items
Collie (GL-X300B) Industrial 4G Gateway | GPS Version
by GL.iNet
Original price €0,00 - Original price €144,74
€90,12
€90,12 - €99,23
Current price €90,12
BEFORE YOU BUY
Currently we only ship to the following countries: Austria, Belgium, Bulgaria, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Ireland, Italy, Latvia, Lithuania, Luxembourg, Malta, Netherlands, Poland, Portugal, Romania, Slovakia, Slovenia, Spain, and Sweden. If your country is not on this list, please purchase from our Global Store HERE.
- Fast delivery (Products will be shipped from Germany).
- Products without the "EU local delivery" tag are shipped from outside the EU and are subject to shipping costs & TAX & longer delivery time.
If the shipping address you provided is not included in the above list, we will contact you to arrange a refund and cancel the order.
Bulk Order
Other Purchase Channels
Order on Amazon DE
Collie (GL-X300B) is an industrial cellular gateway designed to operate under high temperatures and scenarios with potential physical hazards. The GPS version of Collie for providing location tracking data.
Any request for the optional of the additional 128MB Nand Flash, please contact sales@gl-inet.com.
Product Description:
  • Stable CPU: Collie comes with a Qualcomm QCA9531 chipset. It provides stable performance and is also commonly used within the industry, which is perfect for industrial users to avoid breakdown.
  • Built-in 4G LTE Module: Collie comes with a standard SIM card slot that supports the 4G LTE network. It can move into 4G LTE wireless network if the Ethernet Internet fails, in order to ensure constant data transmission in the critical facilities.  Not support Verizon Network in the US.
  • Built-in Watchdog: The Built-in hardware watchdog ensures the stability of Collie. It’s dedicated hardware that can detect and trigger a processor reset if necessary.
  • GPS Module: GL-X300B-GPS provides location data accessible on GoodCloud, and customisable to develop long-range asset tracking applications such as viewing public transport movement.
  • Easy Configuration: Supports AT command, manual/automatic dial number, and signal strength checking in our new admin panel for better management and configuration.
  • Open Source & Programmable: OpenWrt pre-installed. Perfect for developers or IoT integration development.
  • High Security: Supports 30+ VPN service providers, including OpenVPN & WireGuard. Cloudflare and NextDNS supported.
  • Compact Design: Its aluminum alloy shell, optional wall-mounted design, and wide range of operating temperature are designed for easy installation, storage, and operation in tough industrial environments.
            • CPU: QCA9531, @650MHz
            • Memory / Storage: DDR2 128MB / NOR Flash 16MB
            • Protocol: IEEE 802.11b/g/n
            • Wi-Fi Speed: 300Mbps (2.4GHz)
            • Antennas: 2 x 2.4G Antennas, 2 x 4G LTE Antennas, 1 x GPS Antenna
            • Cellular: CAT 4
            • Battery: N/A
            • TF Card Slot: N/A
            • USB Port: N/A
            • Ethernet Speed: 10/100Mbps
            • Power Input: Supports 9-35V wide voltage input 5.5 mm DC power connector or power supply via terminal block
            • Power Consumption: <4W
            • Dimension / Weight: 104 x 113 x 28mm / 235 g
            • Collie (GL-X300B-GPS) Gateway
            • Power Adapter
            • External Antennas
            • Ethernet Cable
            • Mounting Platform & Accessories
            • User Manual
            PINOUT:
            https://docs.gl-inet.com/en/4/user_guide/gl-x300b/hardware_info/#pcb-pinout
